IE3000 image copy
Sep 17th, 2008
I run the archive upload-sw to create tar file on ftp server.
then swap flash card with new one and run dowmload-sw to put image on new flash.
I get
ERROR:Malformed 'info' file
ERROR:Image is not a valid IOS image archive.
I can sh flash ok on both CF cards
Any ideas.
regards
Noel
nbarodia Wed, 09/17/2008 - 21:23
  • Cisco Employee,
Are you running the download-sw command on the tar file or the bin file?
The command works only on the bin file I believe.
So unzip the .bin file from the tar file on the ftp server, download that to the flash and then run the download-sw command.
http://www.cisco.com/en/US/docs/switches/lan/cisco_ie3000/software/release/12.2_44_ex/configuration/guide/swtrbl.html#wp1099467
Nirav
noeldrose Wed, 09/17/2008 - 21:37
I used the upload-sw command which creates a tar file on the ftp server which contains all the files in the image folder including those required for the html interface. I assumed the download-sw would unzip the tar file and recreate the image folder on the new CF card. The switch documentation shows the downlod comand as
archive download-sw /leave-old-sw /reload ftp:[[//username[:password]@location]/directory]/image-name.tar
this references a tar file not bin.
nbarodia Wed, 09/17/2008 - 22:03
  • Cisco Employee,
Thanks for correcting me. The command does accept the tar files.
Is the image filename the same as one you downloaded from CCO?
It does not like any other names.
Can you post the exact upload and download commands you used?
noeldrose Wed, 09/17/2008 - 22:19
I have just purchased the new IE3000. It comes with a removable CF card. I also purchased a spare Cisco CF card. From the telnet comsole I use
archive upload-sw ftp:////.tar
this creates a tar file on the ftp server.
I then remove the existing CF card and insert the new one. I then run
archive download-sw ftp:////.tar
This attempts to unzip the file. the screen shows information like.
loading /.tar!!!!!!!!!!!!
[ok -11875328/4096 bytes]
examining image..
extracting info (103 bytes)
extracting //info (339 bytes)
extracting //info (341 bytes)
ERROR: Malformed 'info' file
ERROR: Image is not a valid IOS image archive
I don't have access to download files from CCO
regards
Noel
nbarodia Wed, 09/17/2008 - 23:44
  • Cisco Employee,
Can you mention what you put in the command and the output for 'sh ver | i 122' please ?
noeldrose Thu, 09/18/2008 - 00:01
I initially tried a file name like ie3000.tar then tried a file name the same as the image name. Both gave the same result.
I'm not on site at the moment and won't be back until Monday local time. Can't get to the switch to try the version command. I will respond when I get back.
Thanks for your help.
regards
Noel
noeldrose Sun, 09/21/2008 - 13:20
Here is the result.
coalhpppcn_ns13#sh ver | i 122
System image file is "flash:/ies-lanbase-mz.122-44.EX1/ies-lanbase-mz.122-44.EX1
.bin"
Motherboard serial number : FOC12241CUF
