Cisco 4503 - Generating Reports
Sep 17th, 2008
Dear All,
I've a got a Cisco 4503 Core Switch.
Would it possible to extract reports? Does it have this feature by default or I needed to enable some feature to be able to generate reports?
PS - Reports like bandwidth usage by IP address, Communication summary between internal hosts and the internet...
Thank you,
Raymond
Overall Rating: 3 (4 ratings)
satish_zanjurne Wed, 09/17/2008 - 21:41
  • Silver, 250 points or more
To generate such types of reports you need to enable Netflow on switch.
NetFlow Statistics is a global traffic monitoring feature that allows flow-level monitoring of all IPv4-routed traffic through the switch using NetFlow Data Export (NDE). Collected statistics can be exported to an external device (NetFlow Collector/Analyzer) for further processing. Network planners can selectively enable NetFlow Statistics (and NDE) on a per-device basis to gain traffic performance, control, or accounting benefits in specific network locations.
NetFlow Flow Statistics are disabled by default.
Switch(config)# ip flow ingress
Switch(config)# ip flow ingress layer2-switched
Switch# show ip cache flow
To configure the switch to export NetFlow Statistics to a workstation when a flow expires, perform one of these tasks:
Switch(config)# ip flow-export destination {hostname | ip-address} udp-port
Switch(config)# ip flow-export version
{1 | {5 [origin-as | peer-as]}}
You can use Cisco Netflow Collector software , or some freeware to collect the Netflow Data..
HTH...rate if helpful..
interedlb Wed, 09/17/2008 - 21:44
What about IP accounting? Does it help when it comes to generating the reports that I'm requesting?
Raymond
satish_zanjurne Wed, 09/17/2008 - 22:07
It may help to certain extent...
Netflow has large number of features & is better.
I am not sure whther you will be able to export the data gnerated by IP Accounting.
finn.poulsen Wed, 09/17/2008 - 23:10
  • Bronze, 100 points or more
In order to run Netflow on a Cat4500 you'll need to buy a Netflow Services card (WS-F4531) unless you have a SUPV-10G or a SUP-6E, which you probably won't in a Cat4503 :-)
