Multiple dial peer
I have a customer that have a CUCM cluster as well as a CME cluster. The CME is the PSTN gateway.
Now, on the CUCM, i have a group of phone which their extensions are not grouped together as follows:
5401
5403
5409
5511
5538
etc
Because the numbers are not together, does it means that on the CME, for the 5 phones, i will need 5 x seperate dial peer to point it to the CUCM cluster??
Is there any way i can group this together into a single dial peer?
Kind Regards,
Hunt
gogasca Wed, 09/17/2008 - 23:42
  • Green, 3000 points or more
Use destination-pattern 5...
Under voip dial-peer
This is what we call wildcards...
MARTIN STREULE Thu, 09/18/2008 - 22:31
  • Silver, 250 points or more
The better match will win.
You should have no problem with "5..." to the CUCM.
CME creates dial-peers (the phones look like FXS ports) to 5500, 5511... These are the more exact matches.
