which switches for iSCSI
Sep 18th, 2008
Hi there,
I am trying to find a two switches (for redundancy) to suit a VMware ESX environment with three servers and an iSCSI SAN. Each server has 6 gigabit connections and the iSCSI SAN 4 so total of 22 ports. Ideally I'd like 2x 16 port gigabit switches to deal with this scenario. What are my options please?
Overall Rating: 3 (2 ratings)
satish_zanjurne Thu, 09/18/2008 - 00:39
Dude !!!
If it R&D setup or production setup follow below guidelines..
1.To connect your hosts in iSCSI, always use GigabitEthernet ports.
2.You can go for Unmanaged switches like Netgear/Dlink.
3.If you want managed switch then use
Cisco Catalyst 2960G-24TC-L
Cisco Catalyst 2960G-48-TC-L
with LAN Base image, as you won't require any configuration.
4.IMP , do not connect iSCSI switch to your production/regular/core network, as it will have lot of broadcasts.
5.Make sure the IP addresses you are using are not used in your production network.
HTH...rate if helpful...
tobiasport Thu, 09/18/2008 - 00:45
Cheers mate.
Its going to be for production. The servers will be on the main lan on these switches and the iSCSI in a separate VLAN to not have the broadcasts be a problem - does that make sense?
