Bandwidth Limiting
Sep 18th, 2008
hi,
i have 2Mb of available bandwidth, i want to reserve 1Mb for my users and 1 MB for my Executives. how can i do that on 3845 router.
satish_zanjurne Thu, 09/18/2008 - 01:36
1.Assuming that Executives & users are in seprate vlan
2.class-map match-all exe-traffic
match access-group 1
class-map match-all user-traffic
match access-group 2
access-list 1 permit exe-vlan
access-list 1 permit any any
access-list 2 permit user-vlan
access-list 2 permit any any
2. Create Policy map & allocate bandwidth
Don't allocate more than 75 percent of total classes
policy-map traffic-policy
class exe-traffic
bandwidth 768
class user-traffic
bandwidth 768
3.Apply policy on WAN interface 2Mbps link
int se0/0
service-policy output traffic-policy
HTH...rate if helpful...
itdsmartnet Thu, 09/18/2008 - 01:59
Thanks for your reply. one thing i would like to ask you that what happens if the traffic exceed than 768 and i want to make sure if the users assigned bandwidth is not used by the users, the executive group will use that bandwidth and if the executives are not using that bandwidth the users will use it.
satish_zanjurne Thu, 09/18/2008 - 02:33
1.During Congestion if the traffic exceeds more than 768, and no bandwidth is available
packets will drop...
2.In your second query, it is YES!!!!
Both class can use unused bandwidth of each other...
HTH..rate if helpful...
itdsmartnet Thu, 09/18/2008 - 02:45
hi,
for the above configuration, what if i want my LAN users to have only 1 MB dedicated and for Executive to have dedicated 1 MB. for any circumstances they should have only one MB each
satish_zanjurne Thu, 09/18/2008 - 03:28
1.You can not allocate the 100 percent bandwidth available.
2.You can only allocate 75 percent of total bandwidth.
3.Remaining 25 percent of bandwidth is used for overhead, including Layer 2 overhead, control traffic, and best-effort traffic.
4.If you need to allocate more than 75 percent ,can use the max-reserved-bandwidth command. The percent argument specifies the maximum percentage of the total interface bandwidth that can be used
5.If you do use the max-reserved-bandwidth command, make sure that not too much bandwidth is taken away from best-effort and control traffic
itdsmartnet Thu, 09/18/2008 - 03:40
hi,
i think you misunderstood. i have configured rate-limiting for LAN users like this:
int gig 0/1
rate-limit input access-group 100 1024000 2048000 2048000 conform-action transmit exceed-action drop
access-list 100 permit ip 10.10.0.0 255.255.0.0 any
will this allow my LAN users having ips 10.10.0.0 to have only 1mb of the avalilable bandwidth ( no matter the remaining bandwidth is free or in use) and remaining will automatically allocated to the Executive users.
Joseph W. Doherty Thu, 09/18/2008 - 05:13
Without going into all the reasons, I would recommend you don't separate normal users and executive users as you've planned (or rate limit).
I would suggest treating all flows FQ or WFQ. If certain traffic is clogging the link, define separate class for it, and provide it minimal bandwidth.
e.g.
class-map match-all bandwidthhog
match protocol ftp
policy-map 2mb_link
class bandwidthhog
bandwidth percent 1
class class-default
fair-queue
If you want to allow executives more bandwidth, relative to ordinary users, when there's congestion, set users flows to BE and executive flows to CS1..CS4. WFQ will give the higher marked flows a larger proportion of bandwidth. (This can also be used with the bandwidth minimal allocation for bandwidth hogs, as shown above.)
itdsmartnet Thu, 09/18/2008 - 20:57
Thanks for your reply. Actually the problem is that i have 2 Mb of bandwidth, the task given to me is that reserve 1 MB dedicated to the LAN users and 1 MB dedicated for the VIPs (Executives) please help me how to configure that.
Joseph W. Doherty Fri, 09/19/2008 - 03:18
Yes, understood what your original problem is. Satish's response shows how to accomplish that, although in his example believe the ACLs should be terminated with denies.
For just splitting your bandwidth 50/50, you just need to identify one or both user's type traffic and split it into two classes. What's important is that each class has the same bandwidth as the other.
My response was recommending not to do what you intend, the 50/50 split, because I believe what I suggested might deliver more consistent network response to both user types.
Since you've asked how to implement a QoS solution, I'm guessing you might not yet fully understand all QoS considerations. If so, one needs to think about what one is really trying to solve. Misuse of QoS can degrade performance (actually it often intentionally does for some traffic).
