Cisco 2500 IP Camera; get screenshot command
Sep 18th, 2008
Hi there,
I have been working with Axis IP Cameras, but for a new project we are going to use Cisco IP Cameras (Cisco 2500 IP Cameras).
Axis IP Cameras offer serveral HTTP commands in order to get current image (jpg) or start a live video stream. Example:
I am looking for a way to do the same with this Cisco IP Camera. So just a HTTP request to the IP Camera to get a current screenshot as response. Does anyone knows if this is possible?
Thanks in advance
Mike-1985 Tue, 09/23/2008 - 00:35
The first links does not shows anything (page is requesting for a long time)
The second link shows a 404-error.
Is there an configuration setup/webpage for the snapshot cgi control? I am looking for a simple HTTP command/url to receive a current snapshot of the live video.
I hope you can provide me with the right info. I have been searching for a while without success.
Dirk-Jan Uitten... Fri, 04/15/2011 - 08:38
Same here... The MJPEG link works but the snapshot URL doesn't.
I was unable to find the IPC-2500 API guide. I did find the API guides for the cheaper camera's. Strange...
I'm also looking for more URLs:
- snapshot with size & quality
- mpjeg stream with different size (without changing the default settings in the camera)
