Destination host unreachable message intermittently
Sep 18th, 2008
Dear Guys ,
M facinf one issue to ping a remote server via FWSM.It is showing Destination host unreachable intermittently.Please let me know what could be the issue...Thanks in advance
Reply from 172.17.117.24: bytes=32 time<1ms TTL=126
Reply from 172.17.10.25: Destination host unreachable.
Reply from 172.17.117.24: bytes=32 time=1ms TTL=126
Farrukh Haroon Thu, 09/18/2008 - 01:56
  • Red, 2250 points or more
Can other hosts ping this machine .25?
Can FWSM ping other hosts in the 172.17.10.x subnet?
Its most probably a routing issue.
Farrukh
manik.palekar Thu, 09/18/2008 - 02:29
hi frd..
172.17.10.25 is a source ip address..I am getting same response from 172.17.117.24 to 172.17.10.25.Those systems which are behind FWSM contex are experiencing this issue..
Farrukh Haroon Thu, 09/18/2008 - 13:40
How is the context setup? ANy shared interfaces etc?
manik.palekar Thu, 09/18/2008 - 23:57
Hi ,Contex configuration is simple as inside & outside ,there is no shared interface.. for outside interface I have comman VLAN ,which is catering to five contex
Farrukh Haroon Fri, 09/19/2008 - 02:32
How are you classifying packets then (mac-auto,static NAT etc)? because you are using a shared interface. From which zone are you initiating the ping?
Farrukh
manik.palekar Fri, 09/19/2008 - 06:43
hi
M initiating ping from one of the inside contex...Outside interface of all Contexs are in commman network subnet
