Site-to-site VPN with dual ASA 5510s
Sep 18th, 2008
I have recently been asked to configure a VPN between two sites using an ASA 5510 at each end. I used the VPN Site-to-site wizard in ASDM on both devices and followed the instructions for the wizard to the letter. However I don't seem able to get any kind of VPN up and running. If anyone could point out where I'm going wrong then I would very much appreciate it.
fraser_chapman Thu, 09/18/2008 - 01:59
Here is the sanitised running config of SiteA:
ASA Version 8.0(2)
hostname MCRASA
domain-name isal.local
enable password xxx
names
interface Ethernet0/0
description External WAN
nameif outside
security-level 0
ip address 81.*.*.82 255.255.255.240
interface Ethernet0/1
description Internal LAN
nameif inside
security-level 100
ip address 192.168.254.2 255.255.255.0
interface Ethernet0/2
description Demarcation zone
nameif dmz
security-level 50
ip address 10.30.30.1 255.255.255.0
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
description MCRASA management
nameif management
security-level 100
ip address 192.168.2.1 255.255.255.0
management-only
passwd xxx
ftp mode passive
dns server-group DefaultDNS
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list outside_1_cryptomap extended permit ip 192.168.254.0 255.255.255.0 host 82.*.*.50
access-list inside_nat0_outbound extended permit ip 192.168.254.0 255.255.255.0 host 82.*.*.50
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu dmz 1500
mtu management 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-602.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
route outside 0.0.0.0 0.0.0.0 81.*.*.82 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable
http 192.168.254.0 255.255.255.0 inside
http 192.168.2.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set pfs
crypto map outside_map 1 set peer 82.*.*.50
crypto map outside_map 1 set transform-set ESP-3DES-SHA
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp enable inside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh 192.168.254.0 255.255.255.0 inside
ssh timeout 5
console timeout 0
management-access management
dhcpd address 192.168.2.2-192.168.2.5 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
webvpn
csd image disk0:/securedesktop-asa-3.2.1.103-k9.pkg
username fraser password xxx encrypted privilege 15
username fraser attributes
memberof LOCAL
tunnel-group 82.*.*.50 type ipsec-l2l
tunnel-group 82.*.*.50 ipsec-attributes
pre-shared-key *
prompt hostname context
Cryptochecksum:xxx
SiteB
ASA Version 8.0(2)
hostname LONASA
enable password xxx
names
nameif Outside
security-level 0
ip address 82.*.*.50 255.255.255.240
nameif Inside
security-level 100
ip address 192.168.1.2 255.255.255.0
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
description LONASA management
nameif management
security-level 100
ip address 192.168.3.1 255.255.255.0
management-only
passwd xxx
boot system disk0:/asa802-k8.bin
ftp mode passive
object-group icmp-type DM_INLINE_ICMP_1
icmp-object echo-reply
icmp-object time-exceeded
access-list Outside_1_cryptomap extended permit ip 192.168.1.0 255.255.255.0 hos
t 81.105.169.81
access-list Inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 ho
st 81.105.169.81
pager lines 24
logging enable
mtu Outside 1500
mtu Inside 1500
mtu management 1500
arp timeout 14400
global (Outside) 101 interface
nat (Inside) 0 access-list Inside_nat0_outbound
nat (Inside) 101 0.0.0.0 0.0.0.0
route Outside 0.0.0.0 0.0.0.0 82.*.*.50 1
http server enable
http 192.168.1.0 255.255.255.0 Inside
http 192.168.3.0 255.255.255.0 management
crypto map Outside_map 1 match address Outside_1_cryptomap
crypto map Outside_map 1 set pfs
crypto map Outside_map 1 set peer 81.*.*.82
crypto map Outside_map 1 set transform-set ESP-3DES-SHA
crypto map Outside_map interface Outside
crypto isakmp enable Outside
crypto isakmp enable Inside
encryption 3des
hash sha
group 2
lifetime 86400
no crypto isakmp nat-traversal
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.3.2-192.168.3.5 management
threat-detection statistics access-list
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
tunnel-group 81.*.*.82 type ipsec-l2l
tunnel-group 81.*.*.82 ipsec-attributes
pre-shared-key *
Cryptochecksum:xxx
singhsaju Fri, 09/19/2008 - 15:24
  • Silver, 250 points or more
Make following changes to your access-lists
Site A
no access-list outside_1_cryptomap
no access-list Inside_nat0_outbound
access-list outside_1_cryptomap extended permit ip 192.168.254.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.168.254.0 255.255.255.0 192.168.1.0 255.255.255.0
crypto map Outside_map 1 match address outside_1_cryptomap
Site B
no access-list Outside_1_cryptomap
access-list Outside_1_cryptomap extended permit ip 192.168.1.0 255.255.255.0 192.168.254.0 255.255.255.0
access-list Inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 192.168.254.0 255.255.255.0
Remove PFS from both sides if it still does not work after you make changes, enable debugs "debug crypto isakmp " , "debug crypto ipsec" and post debugs.
Saju
Pls rate helpful posts
