Alias and SSL vpn vs AnyConnect
Sep 18th, 2008
I have a working remote access SSL vpn on my asa 5505. However, the same SSL vpn does not allow for users to connect using the AnyConnect client software.
If I enable an alias for this SSL group, both the AnyConnect and the SSL vpn login will work just fine.
Any ideas on why?
didyap Wed, 09/24/2008 - 06:03
  • Silver, 250 points or more
For enabling the Enabling AnyConnect Client Connections you need to Create and enable a group alias that displays in the group list on the WebVPN Login page using thegroup-alias command from tunnel group webvpn attributes mode.
robbhanMid Thu, 09/25/2008 - 04:13
I know that. The question was about the need for an alias name to get full functionality.
