AP password
Sep 18th, 2008
Is there any solution to recover the AP password without loosing the entire configuration.
ismail884 Thu, 09/18/2008 - 06:00
I already view the links that you post. but there is only the reset option. I want to just recover the password without loosing my configuration.(is there any procedure to do that like Routers and Switches).
Scott Fella Thu, 09/18/2008 - 18:17
You follow what they show and then instead of deleting the config.old you would:
Rename the configuration file to its original name:
ap# rename flash:config.text.old flash:config.text
Copy the configuration file into memory:
ap# copy flash:config.text system:running-config
Source filename [config.text]?
Destination filename [running-config]?
Press Return in response to the confirmation prompts.
The configuration file is now reloaded, and you can change the password.
Enter global configuration mode:
ap# configure terminal
Change the password:
ap (config)# enable secret password
then wr mem
Scott Fella Fri, 09/19/2008 - 05:16
Did you setup snmp... if so, you can get the config or even push a new configuration. With the 1100, you can only reset the ap.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
