DSL interface down on 2800 router
Sep 18th, 2008
I am trying to make an ADSL Internet connection with 2800 router. ADSL line is working with another brand ADSL router (ADSL_G.dmt modulation, 49 downstream attenuation, 31 attenuation, fast path mode). However when I try to connect 2800 router this line it fails: Debug atm error and events show that, the router announces line quality as bad. How could I change the SNR margins? Also I could not see the controller dsl 0/1/0 on the router configurations.
The configuration is quite simple:
interface ATM0/1/0
no ip address
no ip redirects
no ip proxy-arp
no ip route-cache cef
no ip mroute-cache
load-interval 30
no atm ilmi-keepalive
dsl operating-mode auto
pvc 8/35
pppoe-client dial-pool-number 1
end
CCI-RT-TST-01#sh run int di 0
Building configuration...
Current configuration : 239 bytes
interface Dialer0
ip address negotiated
no ip redirects
no ip proxy-arp
ip mtu 1492
ip virtual-reassembly
encapsulation ppp
dialer pool 1
no cdp enable
ppp pap sent-username xxx password yyy
CCI-RT-TST-01#
*Sep 18 14:06:32: set tx_gain_offset to 0
*Sep 18 14:06:32: set rx_gain_offset to 0
*Sep 18 14:06:32: set target_noise_margin_offset to 0
*Sep 18 14:06:32: set max_bits_tone_limit to 15
*Sep 18 14:06:32: changed current state to do open!!
*Sep 18 14:06:32: DSL: SM: [DMTDSL_DLOAD_2 -> DMTDSL_DO_OPEN]
*Sep 18 14:06:32: DSL(ATM0/1/0): Send ADSL_OPEN command.
*Sep 18 14:06:32: DSL(ATM0/1/0): Using subfunction 0x15
*Sep 18 14:06:32: LOCAL:Max noise margin for power cutoff 31
*Sep 18 14:06:32: DSL(ATM0/1/0): Sent command 0x3
CCI-RT-TST-01#
*Sep 18 14:06:34: DSL(ATM0/1/0): 1: Modem state = 0x8
CCI-RT-TST-01#debug atm erro
*Sep 18 14:06:37: DSL(ATM0/1/0): 2: Modem state = 0x
ATM errors debugging is on
CCI-RT-TST-01#
*Sep 18 14:06:39: DSL(ATM0/1/0): 3: Modem state = 0x10
*Sep 18 14:06:42: DSL(ATM0/1/0): 4: Modem state = 0x10
CCI-RT-TST-01#
*Sep 18 14:06:44: DSL(ATM0/1/0): 5: Modem state = 0x10
*Sep 18 14:06:45: DSL(ATM0/1/0): Received response: 0x22
*Sep 18 14:06:45: DSL(ATM0/1/0): Open failed: Req. min. rate + noise margin + PSD not possible on the line -- retrying
*Sep 18 14:06:45: DSL(ATM0/1/0): sleep 5 seconds
CCI-RT-TST-01#u all
All possible debugging has been turned off
CCI-RT-TST-01#sh dsl int
ATM0/1/0
Alcatel 20150 chipset information
Line has not yet been activated.
Modem Status: Down (DMTDSL_DO_OPEN)
DSL Mode: Unknown
Interrupts: 19871 (0 spurious)
PHY Access Err: 0
Activations: 0
LED Status: OFF
LED On Time: 100
LED Off Time: 100
Init FW: ASW_init_3_8_131.bin
Operation FW: ASW_R3_8_131.bin
FW Source: embedded
DSL: Training log buffer capability is not enabled
