H.320 Channel Bonding Cisco Router
Sep 18th, 2008
we are currently trying to connect a Cisco 2811 Router wit H.320 Channel Bonding with an external ISDN Video Solution. Internally we have a Polycom connected using a gatekeeper on the Cisco Router.
I have used the following document:
http://www.cisco.com/en/US/docs/video/milticomm/h320Bonding.html
Calling in opens 1 channel, but we would need 8 channels. But there is no connect for channel 2-8 on ISDN. Please find also the Router configuration attached:
version 12.4
hostname deflg715
boot-start-marker
boot system flash:c2800nm-ipvoice_ivs-mz1.123-14.T7.bin
boot-end-marker
logging message-counter syslog
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
dot11 syslog
ip source-route
ip cef
no ipv6 cef
isdn switch-type primary-net5
voice class called number pool 100
index 1 5100 - 5108
voice translation-rule 1
rule 1 /^74387251/ /51/
voice translation-profile expandvideo
translate called 1
voice-card 0
no dspfarm
controller E1 0/0/0
pri-group timeslots 1-31
description to PSTN
interface FastEthernet0/0
description *** LOCAL LAN ***
no ip address
duplex auto
speed auto
interface FastEthernet0/0.153
description *** Voice PSTN to ***
encapsulation dot1Q 153
ip address 172.16.64.102 255.255.255.224
h323-gateway voip interface
h323-gateway voip id deflg715.dvbbank.com ipaddr 172.16.64.102 1719
h323-gateway voip h323-id gw
h323-gateway voip tech-prefix 1#
h323-gateway voip bind srcaddr 172.16.64.102
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
description anlagenanschluss +49-69-74387251xx
no ip address
encapsulation hdlc
isdn overlap-receiving
isdn send-alerting
isdn bchan-number-order ascending
isdn sending-complete
isdn integrate calltype all
no cdp enable
logging 10.245.71.35
control-plane
voice-port 0/0/0:15
voice-class called-number-pool 100
translation-profile incoming expandvideo
dial-peer voice 500 pots
information-type video
incoming called-number .T
bandwidth maximum 512
direct-inward-dial
port 0/0/0:15
dial-peer voice 101 pots
destination-pattern 0T
port 0/0/0:15
dial-peer voice 300 voip
destination-pattern 510.
video codec h263
session target ras
incoming called-number 1#.T
tech-prefix 1#
codec g711ulaw
gateway
timer receive-rtp 1200
gatekeeper
zone local deflg715.dvbbank.com dvbbank.com 172.16.64.102
gw-type-prefix 1#* default-technology
no shutdown
Has anybody tried to configure this feature? Any help is appreciated.
Many thanks and with Kind Regards
Christian Hennrich
Joe Vallender Sun, 09/21/2008 - 06:41
  • Bronze, 100 points or more
If you are dialing from your external ISDN video unit to the primary number of your gateway, what are the other 7 numbers being sent back to the originating ISDN unit to dial for the remaining channels? Is the bonding process getting that far? You should be able to capture the logfile in your originating ISDN video unit and see what/if the subsequent numbers are being sent back to it to dial.
Does a 1-channel video call work? I may be poor quality but 'should' work.
