Auto Attendant
Answered Question
Sep 18th, 2008
I finally implemented cisco unity express.Thanks you.
When i call the receptionnist pstn line i want the auto attendant to give me some options like press 0 for operator.How do i do this?
Correct Answer by cg100668 about 8 years 5 months ago
Hi, The configuration for AA in CUE is the same for CUCM and CCME. Please follow the example provided by our dear friend Rob.
Chandrasen
Correct Answer by Rob Huffman about 8 years 5 months ago
Hi Kolawole,
Great work so far! Just wanted to added a little more reading material to the good info posted up by my friend Marwan;
Cisco IPC Express System Configuration Example
Configuring the AA
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/design/CP_CIPExpress/cipce15.html#wp1011557
Auto Attendant Design Considerations
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/design/design21/cueaades.html
Configure and Manage the Cisco Unity Express System Auto Attendant
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_configuration_example09186a00803f82eb.shtml
Troubleshooting Cisco Unity Express Automated Attendant
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/design/CP_CIPExpress/cipce20.html
Hope this helps!
Rob
Overall Rating: 3 (2 ratings)
kolawole1 Thu, 09/18/2008 - 10:00
I am using a call manager 4.1.I think your answer applies to call manager express.Could you provide a way to do it with call manager ?
Correct Answer
Rob Huffman Thu, 09/18/2008 - 04:51
Hi Kolawole,
Configuring the AA
Hope this helps!
Rob
kolawole1 Mon, 09/22/2008 - 05:49
I applied this config (see the file attached) on the router but autoattendant from pstn does not work.10.19.153.2 is the unity express ip address and autoattendant access number is 700.PSTN is 021314876.
Please Help
kolawole1 Thu, 09/18/2008 - 06:10
Thanks.Remember that i am using call manager with mgcp protocol not call manager express.I think your exemple applies to call manager express.Am I wrong ?
Correct Answer
cg100668 Fri, 09/19/2008 - 01:58
Chandrasen
