EzVPN behind private network
Sep 18th, 2008
Is it possible to configure easy vpn behind a private network. The ASA 5505 outside interface is connected behind a switch with a private ip address (192.168.x.x). The tunnel is established between the ASA5520 as a server and the 5505 as a client. I can not access any devices on both network. I only can ping the outside interface of the asa 5505.Which is 192.168.x.x. Please HELP!
mvsheik123 Thu, 09/18/2008 - 05:53
Is 'nat traversal' is enabled on server ASA..? Also, if you enable 'debug icmp trace' , it is easy to t-shoot with 'ping' test. if possible, post the configs.
