AW Configuration Manager Hangs when making changes
Sep 18th, 2008
When I try to modify anything on the "configuration Manager" it just hangs for about 5 minutes and then the changes are executed.
We are using ICM 7.2.5
esa786_2 Mon, 09/29/2008 - 16:55
Hi Experts!! Any reply on this issue useful for many of forum friends
gem
david.macias Tue, 09/30/2008 - 01:56
That is strange, what kind of AD rights does the account you're using have?
david
Riccardo Bua Tue, 09/30/2008 - 05:51
it is most likely a domain resolution problem, do you have a global catalogue close to your AW? Whenever you try an update your security context is verified against the domain, it looks like this query is taking really long in your system, verify also the network for any anomaly.
Riccardo
