CSA Host report problem
Sep 18th, 2008
Hello all. I'm having problems with CSA host report. When I ask for the report the CSA starts generating the report and after scanning 4/5 machines stops and presents me with a pane saying to contact TAC support. Is anyone having/had this problem? Thank and cheers all.
tsteger1 Thu, 09/18/2008 - 10:58
How many hosts are you running the report for and are you choosing HTML or PDF?
Coachramos Fri, 09/19/2008 - 01:14
Hello. I've got 200 hosts and no matter what I choose (HTML ou PDF) it gives always the same error. Thanks U all
tsteger1 Fri, 09/19/2008 - 09:08
Bummer... Mine only generates an error if I try to run a report on more than 1000 hosts.
Try doing only one and see if it works.
