GRE Tunnel & NAT
Answered Question
Sep 18th, 2008
I've setup 2 test routers with a GRE tunnel which is working fine in the test setup. My question is when I transfer this config to a live setup how would I exempt the traffic over the GRE tunnel from being natted? Everything else i.e. traffic destined for the internet should be patted to the outside interface. Would I need a route-map for this?
R1
interface Tunnel0
ip address 192.168.200.2 255.255.255.0
ip ospf network broadcast
keepalive 10 3
tunnel source FastEthernet0
tunnel destination 1.1.1.1
crypto map mymap
interface FastEthernet0
Description Outside Interface
ip address 1.1.1.2 255.255.255.0
speed auto
crypto map mymap
R2
interface Tunnel1
ip address 192.168.200.1 255.255.255.0
keepalive 10 3
tunnel destination 1.1.1.2
crypto map mymap
ip address 1.1.1.1 255.255.255.0
speed auto
crypto map mymap
Correct Answer by singhsaju about 8 years 5 months ago
Yes you are correct.
Overall Rating: 5 (1 ratings)
singhsaju Thu, 09/18/2008 - 09:08
Since there is no "ip nat inside" on the Tunnel interfaces , the traffic going through GRE tunnel will not be NATted . You do not have to bypass NAT in this case.
Saju
Pls rate helpful posts
alraycisco Thu, 09/18/2008 - 09:18
Just to clarify, I can configure the inside and the outside interface for NAT and have no NAT statement on the Tunnel interface, which will cause internet bound traffic to be patted and traffic bound for the GRE tunnel to not be natted?
interface Tunnel1
keepalive 10 3
crypto map mymap
speed auto
crypto map mymap
ip nat outside
Interface Ethernet 0
Description Inside Interface
ip nat Inside
