CUCME 4.0 Outbound dialing delay
Sep 18th, 2008
I have a CUCME 4.0 setup connected to a Verion PRI. Outbound calls work, but there's a 10-15 second delay from when the last number is dialed and the call starts to ring. Is this a CUCME issue, or something on Verizon's end?
slongewa Thu, 09/18/2008 - 07:53
Verizon is really picky about the progress enable bit. Sometimes if you force the progress enable bit you can get the calls to complete faster most of the time - Not sure if this will help your particular situation, but it has worked for me in the past.
On your dial-peer to the PRI
progress_ind
To set a specific progress indicator (PI) in call setup, progress, or connect messages from an H.323 VoIP gateway, use the progress_ind command in dial-peer configuration mode. To reset to the default, use the no or disable forms of this command.
"progress_ind setup enable 3"
progress_ind {setup | connect | progress | alert} {enable pi-number | disable}
no progress_ind {setup | connect | progress | alert}
Note This command is not supported on VoIP gateways using session initiation protocol (SIP).
Syntax Description
setup
Sets the progress indicator for setup messages.
connect
Sets the progress indicator for connect messages.
progress
Sets the progress indicator for progress messages.
alert
Sets the progress indicator for alert messages.
enable pi-number
Progress indicator that is sent in all messages of the specified type from the outbound dial peer. For setup messages from POTS or VoIP dial peers, values are 0, 1, or 3. For progress, connect, or alert messages from a POTS dial peer, values are 1, 2, or 8.
disable
Disables the user configuration of the progress indicator.
gmgarrian Thu, 09/18/2008 - 08:14
Thanks for the info. I implemented your suggestion but I am still getting the delay.
Any other suggestions?
slongewa Thu, 09/18/2008 - 08:28
If you dial a # at the end of the phone number does it get to the telco faster?
Steve
slongewa Thu, 09/18/2008 - 08:51
Your outbound dial peer is not configured correctly. It is waiting for additional digits.
It's something in the configuration like:
dial-peer 123 voice
destination-pattern 9T
port 0/2/0:23
leighharrison Thu, 09/18/2008 - 08:59
  • Gold, 750 points or more
Hi there,
Your problem here is the interdigit timeout settings on the CME. Its setting by default is 10 seconds and this can be dropped down. I find that 3-4 seconds is pretty good. Pressing # forces the router to send the digits, but I find that users don't like doing it, or forget :-(
You need to stuff in:-
conf t
telephony-service
timeouts interdigit (anything from 2 to 120)
Check out this link for more details:-
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_qanda_item09186a0080875c6f.shtml#q2
Hope that helps,
LH
