dual WAN cisco 1811 failover
Sep 18th, 2008
Hello! I have a router cisco 1811 with 2 of the WAN interface.
I have to configure the WAN connection with two different ISPs to allow failover.
My current setup is as follows:
ip route ip_isp-router_1
ip route ip_isp-router_2
With this setup, my LAN can connect to the Internet.
But when I disconect one of the two WAN interface to test failover, does not work.
The LAN lose access to the Internet,
Someone can help me please? or show me basic configuration? I do routing protocols
must create? The NTA will only work with a WAN connection .....
Thank you very much!
Giuseppe Larosa Thu, 09/18/2008 - 10:24
Hello Surfinan,
First of all you need a public address pool from each of the ISP.
Post a filtered version of your config by removing public ip addresses (change them or hide with a X the second and third byte)
So you can get better help
This kind of configuration uses a route-map with multiple clauses to call for the address pools.
Or the two ISPs act as primary and backup and agree on routing to you in case of failure using the second ISP
Hope to help
policreditos Thu, 09/18/2008 - 11:22
Thanks Giuseppe!
I meant NAT, no NTA, jajaj excuse me
Yes, I need to use one ISP to access to the internet and in case this ISP failure, use the second ISP automatically.
Show running-config:
interface FastEthernet0
description $ETH-WAN$
ip address 200.xxx.xxx.201
duplex auto
speed auto
interface FastEthernet1
ip address 200.xxx.xxx.217
duplex auto
speed auto
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-FE 2$
ip address
ip mask-reply
ip directed-broadcast
ip route-cache flow
ip tcp adjust-mss 1452
interface Async1
no ip address
encapsulation slip
ip route 200.xxx.xxx.1 permanent
ip route 200.xxx.xxx.202 permanent
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 1 remark SDM_ACL Category=2
access-list 1 permit
no cdp run
John Blakley Thu, 09/18/2008 - 11:34
Try setting your routes with a higher metric
The route that you want your packets to take most:
The route as a backup
ip route 200.xxx.xxx.202 200
200 is the metric, but it's higher than your first, so the first will always be used unless it isn't responding.
policreditos Thu, 09/18/2008 - 11:59
Thanks John, I'm going to do that.
But still can't access internet from the LAN
If I set NAT yes I can, but this only works with one WAN, and the second WAN doesn't work when the first fails.
Giuseppe Larosa Thu, 09/18/2008 - 12:04
I had understood you were meaning NAT, post your NAT config to get better help.
I agree you need to use a different AD (it is not a metric it is an AD but the suggestion is useful)
Are you using two address pools one from each provider or only one ?
Hope to help
policreditos Thu, 09/18/2008 - 12:21
I don't have NAT enabled, because it works with only one WAN interface.
How I must setup a pool to configure NAT to work with two WAN connections?
John Blakley Thu, 09/18/2008 - 12:43
Not sure, but try this:
ip nat out
ip nat out
ip nat in
access-list 100 permit ip any
ip nat inside sour list 100 int fa0 over
ip nat insid sour list 100 int fa1 over
ip route
ip route 254
I don't know if this will work, but my thought is that the traffic for your "backup" nat pool won't be used unless there's traffic going out that route.
