Meet Me and fast busy
Jaime Valencia Thu, 09/18/2008 - 10:53
you only mentioned you tried to reach the meetme, was it already active??
i mean someone pressed the meet-me softkey, dialed the DN and the other users just the DN??
what's the max number of users?? make sure you do not exceed that
if still no avail restart the IPVMS
java
if this helps, please rate
Jaime Valencia Thu, 09/18/2008 - 14:54
not call establishment, but all media related to IPVMS.
best just to wait after-hours to do this
java
cuevas Wed, 02/04/2009 - 15:07
I'm having the same issue. Where i hit the MeetMe SoftKey, enter in one of the Meet Me Numbers, and i get a Fast Busy. I''ve tried restarting IPVMS, and still get the same results. I've even deleted the and re-added the MeetMe Numbers, Same results.
Thoughts??
FEDEX690220 Fri, 02/20/2009 - 08:27
Exactly the same is happening to me. I wonder whether the config is correct or I might have something missing.
Thanks for the help!!
Luis
swapnendum Sat, 10/15/2011 - 01:50
Check CODEC between Conference Bridge Device Pool and your phone Device Pool's
I had the same issue, fixed it by making G711 between the Regions.
