SSH
Sep 18th, 2008
How do I configure the LMS 3.0 application to accept SSH from the devices. I ant to use SSH to the devices from my LMS machine. I have a sindle server installation. Please help me, thanks.
Joe Clarke Thu, 09/18/2008 - 11:02
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Make sure SSH is selected as a protocol under RME > Admin > Config Mgmt > Transport Settings for all of the config management applications (i.e. Archive, Netconfig, Config Editor). You may also want to check the "Use SSH for software image upgrade and software image import through CLI(with fallback to TELNET)." box under RME > Admin > Software Mgmt > View/Edit Preferences if you want to use SSH instead of telnet when doing image management jobs.
