ACS1113 & allocating client DHCP addresses
Sep 18th, 2008
folks
i think my acs is allocating duplicate IP addresses to remote client vpn clients so i'm gonna try using a dhcp pool on another router and point the relevant group in the acs to the router
has anyone tried this before?
i'd be grateful to hear your experiences
thanks to anyone taking the time to reply
Jagdeep Gambhir Fri, 09/19/2008 - 05:15
I would suggest not to use acs to give ip to vpn clients and use router as a DHCP.
Make sure you have radius accounting enabled. Also what is the software ver of acs ?
~JG
