Cisco 2960 switch-VLAN creation
Sep 18th, 2008
Just a quick simple question...
There are 2 ways of adding the VLAN in switch 2960. Which method should be used.????
1st one is :
vlan database
vlan 104
exit
2nd Method:
vlan vlan-id
name vlan-name
=== Any suggestion, which method should be used. kindly reply.
Mark Yeates Thu, 09/18/2008 - 12:06
  • Gold, 750 points or more
Both will work. The first method is being depreciated using the vlan database. The second method the the newer way of creating vlans in a switch and is recommended.
HTH,
Mark
