simple CCME configuration assistance
Sep 18th, 2008
We have 4 local area codes that
cannot 10 digit dial between eachother. Currently I have pulled all of the configuration attempts I have tried. I cannot get it to work. The local area codes are 763, 651, 612, 952. This cme is located in 651. I want the users to be able to dial 9+763xxxxxxx and have it work there can be delays for 7 digit dialing as long as this works.
Attached is the show run for the CCME.
gmgarrian Thu, 09/18/2008 - 12:31
I'm not sure how much I can help, but can you dial other area codes successfully beside those you listed?
shirwaziri1_2 Thu, 09/18/2008 - 12:39
I have asked that to my client already. i am waiting for a reply. Thanks for your input.
gmgarrian Thu, 09/18/2008 - 12:39
I'm not sure why that double, posted..
Actually, looking closer at your dial peers for those area codes, I noticed you don't have the proceeding "1" in front of the area code:
destination-pattern 9651[2-9]T
I live in RI and I think we're the last state in the US that doesn't require dialing the area code for local calls, so this may not be the issue there. But if other area codes are fine, I'd say it's an issue with those dial-peers. I don't think you really need them since they overlap with regular long distance.
