Boot System command for "switch 2" of stack
Sep 18th, 2008
I have a pair of Catalyst 3750G-TS switches configured in a stack, they are running 12.2(20)SE4 IOS.
I have manually copied down an IOS to each switch by doing the following:
erase flash:
copy tftp flash:
<IP Address>
c3750-ipservicesk9-mz.122-35.SE5.bin
session 2
erase flash:
exi
copy tftp:c3750-ipservicesk9-mz.122-35.SE5.bin flash2:
The "boot system switch" command is not a valid command, so I used "boot system flash:c3750-ipservicesk9-mz.122-35.SE5.bin" and it took it fine.
When I do a "show boot", I see that boot path is set correctly, but when I go in to the second switch using "session 2" and perform a "show boot", it indicates that it is pointing to the old IOS.
Is there a way to set the boot path for the second switch manually?
Mark Yeates Thu, 09/18/2008 - 13:15
Try using the "boot system switch all flash:c3750-ipservicesk9-mz.122-35.SE5.bin" command on the stackmaster switch. That should update the boot variable on all the switches in the stack.
HTH,
Mark
glen.grant Thu, 09/18/2008 - 17:22
Mark is correct and when do a show boot is will show as both switches with the same variable . If for some reason you have a slightly different version on the second switch you can have separate boot statements pointing to the individual switch though it is reccomended that all switches run the same version.
satish_zanjurne Thu, 09/18/2008 - 20:36
Hope you have copied the IOS properly, still see following guidelines.
1.Switch#dir flash1:
2.Switch#dir flash2:
In a Catalyst 3750 switch stack, flash: represents the Flash file system of the master switch.
3.Switch#copy tftp: flash1:
4.Switch#copy tftp: flash2:
Configure the boot variable to boot the switch with the newly copied IOS:
5.Switch(config)#boot system switch all flash:/c3750-advipservicesk9-mz.122-25.SEE2.bin
6.Switch#write memory
Verify the boot variable:
7.Switch#show boot
Verify that the new IOS file is present in the Flash:
9.Switch#dir flash1:
10.Switch#dir flash2:
11.Reload
To set the boot variable for individyal switch use followign command.
3750-stack(config)#boot system switch 3 flash:/c3750-advipservicesk9-mz.
122-25.SEE1.bin
Make sure the IOS file you have copied in root directory or inside directory.
in dir flash:
you should be able to see the difference
the file ending with just like SEE1 , SEE are directories.
the file ending with like SEE1.bin , SEE.bin
are actual IOS/image files.
You need tp modify your boot variable accordingly
HTH...rate if helpful..
