PPTP and Zone based Firewall
Sep 18th, 2008
Pls help! I configured Zone based firewall and here are a part of my config file:
class-map type inspect match-any test
match protocol tcp
match protocol udp
class-map type inspect match-all sdm-cls--3
match access-group name Public
class-map type inspect match-all sdm-cls--2
match access-group name Internet
match class-map test
class-map type inspect match-all sdm-cls--1
match access-group name LAN
class-map type inspect match-all sdm-cls--5
match access-group name pristup
class-map type inspect match-all sdm-cls--4
match access-group name VPN
policy-map type inspect sdm-policy-sdm-cls--1
class type inspect sdm-cls--1
inspect
class class-default
policy-map type inspect sdm-policy-sdm-cls--3
class type inspect sdm-cls--3
inspect
class class-default
policy-map type inspect sdm-policy-sdm-cls--2
class type inspect sdm-cls--2
inspect
class class-default
pass
policy-map type inspect sdm-policy-sdm-cls--5
class type inspect sdm-cls--5
inspect
class class-default
policy-map type inspect sdm-policy-sdm-cls--4
class type inspect sdm-cls--4
inspect
class class-default
zone security visitors
zone security employee
zone security Internet
zone security VPN
zone-pair security sdm-zp-visitors-employee source visitors destination employee
service-policy type inspect sdm-policy-sdm-cls--1
zone-pair security sdm-zp-employee-Internet source employee destination Internet
service-policy type inspect sdm-policy-sdm-cls--2
zone-pair security sdm-zp-visitors-Internet source visitors destination Internet
service-policy type inspect sdm-policy-sdm-cls--3
zone-pair security sdm-zp-VPN-employee source VPN destination employee
service-policy type inspect sdm-policy-sdm-cls--4
zone-pair security sdm-zp-Internet-employee source Internet destination employee
service-policy type inspect sdm-policy-sdm-cls--5
ip access-list extended Internet
remark SDM_ACL Category=128
permit ip 192.168.201.0 0.0.0.255 any
With this configuration user from inside cannot establish PPTP connection to outside PPTP server. Where is my mistake?
Gerald Vogt Fri, 09/19/2008 - 00:35
I assume here the users are in the employee zone and the PPTP server is in the internet zone.
PPTP uses a TCP connection to establish a GRE link. Your policy sdm-policy-sdm-cls--2 only inspects class sdm-cls--2, i.e. you only inspect tcp and udp traffic. Anything else is passed without inspection.
You don't posted the access list pristup but I guess it won't accept incoming GRE.
I would say you have to remove the test class-map from the sdm-cls--2 class to inspect all IP protocols and not only tcp and udp. Or you add gre to the test class-map if gre is support for "match protocol".
Generally, I find it helpful for debugging to have a "drop log" rule for class-default where you don't pass traffic. It shows you which policy drops the packet and may give you a hint where the problem is.
