permitting DHCP requests through PIX/ASA
Answered Question
Sep 18th, 2008
what are the exact ACL permit statements that i need to configure on my firewall if dhcp clients are residing on the inside network and DHCP server on the outside network, Assuming that i have access-group statments applied on both inside and outside interface in the inward direction.
Correct Answer by satish_zanjurne about 8 years 4 months ago
In routed firewall mode, broadcast and multicast traffic is blocked even if you allow it in an access list, including unsupported dynamic routing protocols and DHCP (unless you configure DHCP relay). Transparent firewall mode can allow any IP traffic through.
1.If you are not using ASA/PIX in transparent mode, then you need to make ASA/PIX as DHCP Relay Agent
dhcprelay server x.x.x.x outside
dhcprelay enable inside
dhcprelay setroute inside
2.If you are using AS/PIX in transparent mode then you need to basically allow UDP port 67 & 68
HTH..rate if helpfull...
Overall Rating: 4 (2 ratings)
Syed Iftekhar Ahmed Fri, 09/19/2008 - 01:02
ASA must be in transparent mode for DHCP requests to pass through
Following is an example to achieve what you are looking for
(DHCP SERVER: 10.10.10.10) ----- OUTSIDE(ASA)INSIDE ---DHCP Clients
Apply this on outside interface (bootpc = port67)
access-list 10 extended permit udp host 10.10.10.10 any eq bootpc
Apply this on Inside interface (bootps = port 68)
access-list 20 extended permit udp any any eq bootps
Syed Iftekhar Ahmed
Correct Answer
satish_zanjurne Fri, 09/19/2008 - 01:12
