Export topology view
Answered Question
Sep 18th, 2008
From topology view, I have change the topology (using username "A"), can I export topology to the other user (using username "B") so if I using username "B", the topology view will be the same as if I using username "A".
Correct Answer by Joe Clarke about 8 years 4 months ago
The topology layout can be shared with another user by copying the *.xml files under NMSROOT/campus/etc/users/A to NMSROOT/campus/etc/users/B. You will probably also want to copy the user.preference file.
Overall Rating: 4 (1 ratings)
Correct Answer
Joe Clarke Thu, 09/18/2008 - 22:22
riko.arizona Mon, 09/22/2008 - 00:56
Right now I can shared my topology layout for the other users. Thank You so much.
