How to avoid missed calls history on SHARED lines?
Sep 18th, 2008
I have a setup intensively using Barge and Privacy feature with shared lines. Users IP phones are configured with their primary extension, as well as with Directory Number of their colleagues (as shared lines).
My issue is that when a colleague DN is called with no answer, this call appears as missed call on every ip phone sharing this DN, while I'd like it to appear on the colleague phone only.
Is there a way to restrict missed calls history to only display missed calls received on the primary line and not those received on other shared lines?
Many thanks,
Laurent
Overall Rating: 5 (1 ratings)
gogasca Thu, 09/18/2008 - 23:58
  • Green, 3000 points or more
Hi Laurent,
This is documented in: CSCdt61023
In the 8.0(3) phone firmware, there is an indication as to which line a missed
call was received on, and there are options to view call details or delete specific entries from the call history logs.
However, these features only apply to the 7911, 7941, 7961, 7970 and 7971 phone models.
No plans to implement these on the 7905, 7912, 7940 or 7960.
You get a "details" softkey that brings up an extra screen full of info.
l.demanet Fri, 09/19/2008 - 00:04
Thank you for your reply. Seeing CSCdt61023 details, I understand I4m not the only one willing the feature.
Actually my version (5.1.3 and 7961) does display in the missed called history which line was called, but it's not handy as one phone can share up to 19 lines... So users need to go through ALL missed calls, looking on which line it was received.
Anyway, thank you again for your input!
Laurent
Rob Huffman Fri, 09/19/2008 - 04:49
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hey Gonz,
Hope all is well my friend! Thanks for posting up this bug, I had never actually seen this anywhere. +5 points for your always stellar support :)
Take care,
Rob
