Unable to Access Resource in inside network using Remote Access VPN
Sep 19th, 2008
Hi Guys,
This question seems to be routine one for all you,but its been a problem for me to come out of it,I went through most of the posts of same nature to troubleshoot it but i didnt find any result.I am able to connect to my ASA using VPN and establish a tunnel there after i couldnt ping any one inside the network .
I am attaching my Running configuration please help me in this regard.
tyagi.v Fri, 09/19/2008 - 01:08
Put these commands in the ASA:-
crypto isakmp nat-traversal
sysopt connection permit-vpn
For testing purpose only remove the inside access-list with:-
no access-group inside-acl in interface inside
Also disable IPS functionality for time being then check it.
sreekanth sarma Sun, 09/21/2008 - 22:36
Hi all
I tried all i can do in this regard
1. management-access inside
2. crypto iskamp nat transversal
3.same-security interface permit intra
but i couldnt reach my inside network i am able to ping my inside interface of my asa but i am not able to ping any of the inside hosts
please can any one help me
