AIR-AP1253 antennas
Sep 19th, 2008
I have to install 3 AIR-AP1252 with ceilling antennas 2,4GHz (AIR-ANT2430V)and 5Ghz (AIR-ANT5140V) with both ones.
Is there any recommendation about the minimun distance of separation between both kind of antennas (2,4Ghz and 5Ghz)which are connected to the same AP-1252.
Scott Fella Fri, 09/19/2008 - 05:25
No.... it depends on your ceiling tile. Usually on a 2x2 tile, they are mounted on opposite sides. It can be mounted on the same grid if both will fit like in a 2x3 or 2x6... etc.
rob.huffman Fri, 09/19/2008 - 05:31
Hi Enrique,
Have a look at this good discussion that deals with this question. There are some really interesting answers and even Cisco TME Fred weighs in with a superb explanation;
Hope this helps!
