allowing ping to ipsec remote access clients
Sep 19th, 2008
Hi all, can anyone tell me how i can ping my remote access clients from inside my network, there is no access list on the inside interface so I would of thought it should work, do I need to create a rule allowing the echo reply back through ?
satish_zanjurne Fri, 09/19/2008 - 01:20
If you have established the IPSec with remote access clients, then you should be able to ping them directly, because the IP Address pool for remote access clients , must be routable.
Otherwise,
First Option is
1.The first option is to
setup a specific rule for each type of echo message.
access-list 101 permit icmp any any echo-reply
access-list 101 permit icmp any any source-quench
access-list 101 permit icmp any any unreachable
access-list 101 permit icmp any any time-exceeded
access-group 101 in interface outside
2.Second Option is to to configure ICMP inspection.This allows a trusted IP address to traverse the firewall and
allows replies back to the trusted address only. This way, hosts on all inside interfaces can ping hosts on the
outside and the firewall allows the replies to return. This also gives you the advantage of monitoring the
ICMP traffic that traverses the firewall.
policy-map global_policy
class inspection_default
inspect icmp
HTH...rate if helpful..
carl_townshend Fri, 09/19/2008 - 02:52
how should it normally work, should it work with inspection off, and no access lists, when pinging from inside to outside.
