09-19-2008 03:13 AM - last edited on 03-25-2019 07:11 PM by ciscomoderator
Dear all,
I am experiencing some problems when programming in CRS editor an script for IPCCX 5.0(2).
When I try to get a user using the Get User step with the Query Type = Agent Extension and providing the "extensionNumber" it always enters in the Unsuccessful branch.
If I try to do it selecting Query Type = User ID it works perfectly.
I include an attachment as example. When using the "1752" extension I get no agent in the "AgentePorExt" variable. But when using the "PRUEBAS3" id I get the agent in the "Agente" variable and also its associated extension in the "Ext" variable.
Could anybody let me know what is wrong when trying to use the Extension in the Get User step?
Thanks in advance,
BR, Amaia
04-03-2009 06:53 AM
Dear Amaia,
Have you resolved this issue because I've the same one...
Thanks in advance.
Best regards
Romain JOURDY
04-03-2009 08:21 AM
Dear Romain,
I couldn't solve it. In the end I managed to get what I want using the UserID.
Maybe an upgrade of the system solves it.
Plese, let me know if you solve it.
Best regards,
Amaia Lesta
04-03-2009 08:46 AM
Dear Amaia,
I solve it!
In fact I'de twice resourceid with same extension.
To verify it you can go on the resource table and check if you have twice agents with the same extension. If it is the case erase one in appadmin and it will ok.
Best regards
04-05-2009 11:28 PM
Ok!! Wonderful!! Thanks a lot for your pieace of advice, I will try it.
