Not all numbers connect
Sep 19th, 2008
I have a 2811 running MGCP to a PRI interface. Most calls connect with no issue however, we have several numbers that when dialed we get back a busy tone, the number dialed is not busy. On the debug it looks like we have normal clearing.
Any ideas would be great.
terryneill Fri, 09/19/2008 - 17:07
Any reason why you are using overlap sending as opposed to enbloc?
I have seen issues with overlap sending if the provider end is not set to recieve such signalling.
see the link below:
This explains overlap sending and how to enable it, to disable it just perform the reverse and uncheck overlap sendind from your route patterns.
m_mackenzie Mon, 09/22/2008 - 23:46
We are using overlap to reduce the time on the call placement. The call works from an IP phone.
