10 sec call setup delay on H.323 gateway
Sep 19th, 2008
Hey guys. I'm having an issue with an H.323 gateway and long call-setup delay. It is taking around 10 seconds from the last digit input to the time it dials out. The calls are being handed to a Call Manager for processing to the PSTN. I've checked everything and can't find where I can minimize the delay. Any suggestions?
Thanks in advance.
Jaime Valencia Fri, 09/19/2008 - 09:53
first thing to always check is dial plan overlapping, probably you have something in there that causes this to expect more digits
if still no avail modify the T_302 timer
if this helps, please rate
nalonsoamerex Fri, 09/19/2008 - 10:01
This is my dial-peer voip session to hand call to CCM. There is this one and the another one with preference 2 for the subscriber.
dial-peer voice 10 voip
preference 1
destination-pattern 9T
voice-class codec 100
voice-class h323 1
session target ipv4:##.##.##.##
dtmf-relay h245-alphanumeric
fax-relay ecm disable
fax protocol pass-through g711ulaw
ip qos dscp cs5 media
no vad
From the call manager it looks good. If I dial the same numbers over the cisco phones they dial out immediatly. What gives?
nalonsoamerex Fri, 09/19/2008 - 12:01
I figured it out. The destination pattern 9T is not specific enough and it was waiting for more digit inputs. I changed it to 9[1].......... and 9[2-9]......... and it's all good now.
Thanks for your help.
chadlincoln Mon, 09/22/2008 - 11:24
You can also set the interdigit time out under the telephony services.
timeout interdigit 7
