inspect icmp
Sep 19th, 2008
While we are on the topic. Whenever I add the "fix protocol icmp" command on version 8.0 ASA 5520. My telnet session to the inside will no longer work. Is there anyway around that?
jjohnston1127 Fri, 09/19/2008 - 10:13
  • Silver, 250 points or more
What happens if you put in the command:
management-access inside
robertson.michael Fri, 09/19/2008 - 13:34
The 'fixup protocol' commands were used in PIX 6.x code. In ASA 7.x and 8.x, this functionality has moved to the MPF.
To enable ICMP inspection in ASA 8.x, your config would look something like this:
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect icmp
service-policy global_policy global
Also, for telnet access to the inside interface, you'll want to configure something like this:
telnet inside
Hope that helps.
-Mike
cisco24x7 Fri, 09/19/2008 - 17:26
You still CAN enter "fixup protocol ftp 21"
on Pix 7.x and 8.x code. It will automatically
convert into Modular Policy Framework (MDF)
for you.
I didn't try "fixup protocol icmp" in version
8.x because my Pix firewall crashed but I
think it will work as well.
