Can't call local number with VOIP phone
Sep 19th, 2008
Hi guys, there is a local number that we can't dial with voip phone, it goes through maybe 30% of the time. Do you guys know of anything I can use to analyze the call or any ideas what the problem could be, we are runnig CM4.x? Phone number can be reached through PBX and cell phone 100% of the time. thanks
Jaime Valencia Fri, 09/19/2008 - 12:53
  • Cisco Employee,
  • Hall of Fame,
    2011
yes, you need traces and debugs to troubleshoot something like this and find what's causing this
java
if this helps, please rate
espereir Fri, 09/26/2008 - 21:33
  • Silver, 250 points or more
Have you tried to use the Dialed Number Analyzer plugin that is included with CUCM? If you have CCM 4.X you will need to download it from the plugins page and install it on the Publisher, and if you have CUCM Appliance (Linux) you just need to enable it from the Service Activation page on Serviceability.
The URL is https:///DNA
This plugin will show you additional details why the call failed and will give you a full digit analysis and what happened with the call.
It is easier to check it here rather than taking traces ;) .
For 5.X or higher:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/dna/6_0_1/dnaacc.html
For 3.X until 4.X:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/dna/3_3_4/cdna334.html
Please let us know how it goes!!!
