Hardening ASA
Amin Shaikh
IS there steps on cisco site on
How to harden ASA and avoid password recovery..
Marwan ALshawi
hi there
Cisco ASA can disable the password recovery process, This ensures that even if an unauthorized user gets access to the console port, they should not be able to compromise the device or configuration settings
Use the:
no service password-recovery
command to disable password recovery from configuration mode
this is how to enter the command and the warring will apear:
ASA(config)# no service password-recovery
WARNING: Executing "no service password-recovery" has disabled the password recovery
mechanism and disabled access to ROMMON. The only means of recovering from lost or
forgotten passwords will be for ROMMON to erase all file systems including
configuration files and images. You should make a backup of your configuration and
have a mechanism to restore images from the ROMMON command line
good luck
if helpful Rate
