Mark Yeates Fri, 09/19/2008 - 10:58
  • Gold, 750 points or more
There really isn't any difference in the switch besides the port speeds. You shouldn't have to do anything besides copy and paste the config into the new 3750G switch.
HTH,
Mark
andrew.butterworth Fri, 09/19/2008 - 11:33
You will have to do a search and replace for 'FastEthernet' to 'GigabitEthernet' in the config file though :o)
Andy
Mark Yeates Fri, 09/19/2008 - 11:44
Sorry I kinda forgot about doing that... In word pad do a replace FastEthernet with GigabitEthernet will change it. Also there is one additional thing I forgot is your SFP ports will change also to Gi1/0/49-52 since all ports on the switch are gigabit.
Mark
P.S. Thanks Andy for pointing that out!
