static NAT to two ISPs
Answered Question
Sep 19th, 2008
On an ASA, I can do the following:
static (inside,isp1) 10.10.1.10 192.168.8.10 netmask 255.255.255.255
static (inside,isp2) 10.11.1.10 192.168.8.10 netmask 255.255.255.255
This allows the ASA to respond to traffic on either public interface, on behalf of the private interface, albeit with a return path specified by the routing table.
How can I do the same thing on a 2811 router?
If I try to enter two NAT statements using different public IPs, but the same private IP, the 2nd one overwrites the 1st.
Any help would be most appreciated.
Correct Answer by m-haddad about 8 years 7 months ago
Just use two different route-maps within the static NAT and this should do the trick.
Overall Rating: 5 (1 ratings)
Correct Answer
m-haddad Fri, 09/19/2008 - 12:10
  • Silver, 250 points or more
maltuna Fri, 09/19/2008 - 12:12
Ahh, that makes sense. I was wondering why I couldn't specify the interface if I entered an IP, but I can specify the interface using a route-map. I will try this.
Thank you !
m-haddad Fri, 09/19/2008 - 13:04
Glad I could help and keep me posted if you have issues,
Thanks for the rating,
