09-19-2008 12:17 PM - edited 03-10-2019 04:05 PM
When connecting to a Pix using SSH, are there any versions that support changing your tacacs password?
09-19-2008 12:41 PM
That is not supported on Pix. (CSCdx79225) for the enhancement request on the PIX,
You can view this here:
http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl
~JG
Do rate helpful posts
09-19-2008 01:20 PM
That bug is for password aging...not sure if this is the same thing. I would like to know if when I log in, can I change my password.
Also would like to know if this is supported with ASA.
