Mark Yeates Fri, 09/19/2008 - 13:15
  • Gold, 750 points or more
What router are you using? Also what is the WIC you are trying use and what IOS version are you running?
Mark
WGUNTERCISCO Fri, 09/19/2008 - 13:22
1720 router with 1enet wic,
IOS (tm) C1700 Software (C1700-Y-M), Version 12.2(7c), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Fri 10-May-02 19:06 by pwade
Image text-base: 0x800080E0, data-base: 0x806F2D18
ROM: System Bootstrap, Version 12.0(3)T, RELEASE SOFTWARE (fc1)
any help would be great!
Mark Yeates Fri, 09/19/2008 - 13:28
It looks like you will need an IOS upgrade for this card to work.
The Cisco WIC-1ENET card requires Cisco IOS Release 12.2(2)XJ or later if the card is installed in any WIC slot other than slot 0 or if more than one card is installed.
The card can be used with Cisco IOS Release 12.2(4)T, but the card must be installed in slot 0 and only one Cisco WIC-1ENET card can be installed in the router.
HTH,
Mark
WGUNTERCISCO Fri, 09/19/2008 - 13:33
The card is in slot 0 and it is the only WIC installed. does 12.2(7) support this.
Mark Yeates Fri, 09/19/2008 - 13:41
It requires 12.2(7)T. That is a completely different release than what you currently have.
Mark
WGUNTERCISCO Fri, 09/19/2008 - 13:48
How can I get a copy of the IOS. The cisco website will not let me download?
Mark Yeates Fri, 09/19/2008 - 13:54
You will need a valid SMARTnet contract on the router to be able to download software updates for your router from Cisco.
Mark
WGUNTERCISCO Fri, 09/19/2008 - 14:02
Will this version work?
System Bootstrap, Version 12.2(7r)XM2, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 2003 by cisco Systems, Inc.
C1700 platform with 65536 Kbytes of main memory
Mark Yeates Fri, 09/19/2008 - 14:06
That seems to not be an IOS version, but bootstrap for the router itself.
WGUNTERCISCO Fri, 09/19/2008 - 14:13
Cisco IOS Software, C1700 Software (C1700-IPBASE-M), Version 12.4(5), RELEASE SO
FTWARE (fc3)
How about this one?
