how to find what version you are running
Sep 19th, 2008
Hi all. Im was told I need to update my "underlying" OS of a Unity server. I have seen an app run that I recall being a Cisco link on one client's server to see what version of Windows would be reported, but I have no idea how to find that. Does nayone have any insight or even any idea what I might be talking about to find out what version of OS Im running? Thanks in advance
Overall Rating: 4 (2 ratings)
jkosciuk Fri, 09/19/2008 - 13:05
log on to the server click on start and near the top on the start menu you will see the prompt for Cisco OS version
Jaime Valencia Fri, 09/19/2008 - 16:49
  • Cisco Employee,
  • Hall of Fame,
    2011
that suggestion is for CUCM so it's useless for Unity. simply right click on My computer -> Properties
or go to System Tools -> System Information
java
if this helps, please rate
Justin Brenton Sat, 09/20/2008 - 19:03
  • Silver, 250 points or more
Hi JJoseph01,
You can use Gather Unity System Info tool, you can find this tool in the Unity Tools depot under Reporting Tools.
This will help you find info on the Unity version and such. For the Windows OS info you will need to goto start - programs - accessories - system tools - system information.
Hope this helps, Please rate if so.
Justin
jjoseph01 Mon, 09/22/2008 - 05:05
Thanks guys. I appreciate it. I didnt know that the first response was for CUCM only. Thanks again.
