4500 boot
Sep 19th, 2008
i dont know why the ios on the sup-6e was deleted.
how boot from tftp server, im receiving a error message when i type boot tftp://192.168......
Overall Rating: 5 (2 ratings)
Rafael Jimenez Fri, 09/19/2008 - 17:32
Mark, the supervisor module in the CAT4510R-E is 6-E,
I follow the instructions but I still having problems..., I did a copy of IOS and renamed it ios.bin
rommon 3 >boot tftp://
Tftp Session details are ....
Filename : /ios.bin
IP Address :
Loading from TftpServer:
Tftp session failed: Access violation
rommon 4 >
My tftpd32 program show this error...
Error EACCESS on file /ios.bin Ext error The directory name is invalid.
I tried many ways with the ios.bin location (in the root /, with subdirectory tftpboot f.e.x...I don't know what is the problem.....
please help me.
Mark Yeates Fri, 09/19/2008 - 17:49
There seems to be an issue with your TFTP server. Tftpd32 is a great TFTP server but can be a little more complex than it should be. I keep a folder on the C: drive called TFTP with all the TFTP contents and keep the security at none. If you want to try something a little easier I also recommend solar winds TFTP server.
PS: Don't forget to disable or allow TFTP access temporarily through your desktop firewall if you have one.
Rafael Jimenez Sat, 09/20/2008 - 09:07
For time reasons not was possible continues troubleshooting with the tftp server. I just use a Compact Flash in the slot0 with the ios. after boot i just copy the ios to the bootflash and change the boot variables.
Rafael Jimenez Sat, 09/20/2008 - 09:45
I believe the problem is the BOOTLDR variable. But I don't had time to test it.
Mark Yeates Sat, 09/20/2008 - 09:50
You can find the values in the link I posted before to configure the BOOTLDR variables.
carlos.asensio Wed, 09/24/2008 - 02:25
I had the same problem.
Just upgrade to the latest version of tftpd32 and everything worked fine!
