CME redirecting number
Sep 19th, 2008
i am having issues call forwarding to a 1866 number in Canada. I can call forward to any other number.I have engaged the telco and they have asked me in get the redirecting number to put out the whole number instead of the 1700
Redirecting Number i = 0x00008F, '1700'
Redirecting Number i = 0x00008F, 'XXXXXX1700'
voice translation-profile expand
translate called 10
voice translation-rule 10
rule 1 /^1700/ /XXXXXX1700/
dial-peer voice 1 pots
translation-profile incoming MainLine
incoming called-number .
port 0/3/0:23
dial-peer voice 10 pots
description 91... Via PRI
translation-profile outgoing expand
preference 1
destination-pattern 91..........
port 0/3/0:23
forward-digits 11
Any ideas where i am going wrong ?
gogasca Fri, 09/19/2008 - 15:45
U r in the right direction, just change the
translate called 10
to "translate redirect" and u can test it later.
Marwan ALshawi Fri, 09/19/2008 - 18:29
i c the problem in the dial-peer
ur dial-peer matching a number consist of 12 digits and start with 91 while the applied translation profile match any number start with 1700 then they wont work
to solve it try to change the distination pattren it the user or the number dialed only 1700 make another dial-peer like
dial-peer voice 11 pots
destination-pattern 1700
port 0/3/0:23
forward-digit all
one more thing, what dose the following translation profile do ?
" translation-profile incoming MainLine "
good luck
if helpful Rate
