IP Phone 7960 (SIP or SCCP)
Answered Question
Sep 19th, 2008
What does SIP and SCCP mean ?
How do know if our phones Cisco IP Phone 7960 is SIP or SCCP ?
thank you
Correct Answer by terryneill about 8 years 9 months ago
These are basically two different signalling protocols. SCCP is the native signalling used with Callmanager SCCP is also called Skinny, SIP is an open standard.
Most Callmanager deployments in my experience are still using SCCP for signalling.
The 7960 can support either SCCP or SIP.
I would recommend using SCCP unless there is a specific reason to use SIP.
Hope this helps.
Overall Rating: 4 (1 ratings)
Correct Answer
terryneill Fri, 09/19/2008 - 17:10
Hope this helps.
