MOH for linksys phone in CME 4.0
Sep 19th, 2008
I registered 3 SIP phones (linksys)in a CME 4.0 but when I have a call in linksys phone and then put in hold any call I don't listen the music of MOH from the flash.
As far as I know there must be another source for the MOH for linksys phone but I don't know how to set ?
any reference?
Rob Huffman Sat, 09/20/2008 - 09:16
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Filiberto,
I think that you require at least CME 4.1 to support MOH on SIP Phones;
Music on Hold for SIP Phones
In Cisco Unified CME 4.1 and later versions, the MOH feature is supported when a call is put on hold from a SIP phone and when the user of a SIP phone is put on hold by a SIP, SCCP, or POTS endpoint. The holder (party that pressed the hold key) or holdee (party who is put on hold) can be on the same Cisco Unified CME or a different Cisco Unified CME connected through a SIP trunk. MOH is also supported for call transfers and conferencing, with or without a transcoding device.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmemoh.html#wp1010372
Configuring MOH for SIP phones is the same as configuring MOH for SCCP phones. For configuration information, see
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmemoh.html#wp1010384
Hope this helps!
Rob
Rob Huffman Sun, 09/21/2008 - 10:02
  • Hall of Fame,
    Founding Member
Hi Filiberto,
You are most welcome my friend! Have a great day.
Cheers!
Rob
filiberto.aguirre Thu, 09/25/2008 - 19:17
Hi Rob
I have already carried out some test with linksys's phone registerd in CME 4.2 I have the following issues
a) when the holder is a cisco IP phone and the holdee is a linksys phone, MOH works fine
b) when the holder is a linksys phone and the holdee is a cisco IP phone, MOH is not listen.
c) when the holder and holdee are linksys phone I just listen a beep tone.
voice register global
mode cme
source-address 10.10.10.1 port 5060
max-dn 5
max-pool 5
timezone 9
date-format D/M/Y
hold-alert
file text
create profile sync 0834091551485355
voice register dn 1
number 3251
call-forward b2bua busy 600
call-forward b2bua noan 600 timeout 15
name filo
label 325
voice register dn 2
number 3884
name Filo
label 3884
voice register dn 3
number 3864
name GeNA
no-reg
label 3864
voice register dn 4
number 9745
name Nabor
label 9745
voice register dn 5
number 3252
name 3252
label 3252
voice register pool 1
id mac 000E.08DE.048A
number 1 dn 1
max registrations 48
dtmf-relay sip-notify
username 3251 password 3251
codec g711ulaw
voice register pool 2
id mac 000E.08DF.500D
number 1 dn 2
cor outgoing LADA 1 901
username 3884 password 3884
codec g711ulaw
voice register pool 5
id mac 000E.08D0.4E75
number 1 dn 5
username 3252 password 3252
codec g711ulaw
By another hand I set the option of moh in telephony service
telephony-service
moh music-on-hold.au
multicast moh 239.10.16.4 port 2000
I don't know if I have to set something else in linksys phone so that it works fine MOH in all the scenarios.
regards,
