Giuseppe Larosa Fri, 09/19/2008 - 23:06
  • Hall of Fame,
    Founding Member
Hello Akbihari,
if you are going to use a L3 MPLS VPN service you can use XoT (X.25 over TCP) between your CE routers at the two sites.
In this way X.25 frames will be carried inside TCP segments as IP traffic and will be routed by the MPLS service.
You may need to use QoS to provide a better treatment to XoT packets.
see
http://www.cisco.com/en/US/tech/tk827/tk369/tk746/tsd_technology_support_sub-protocol_home.html
Hope to help
Giuseppe
