09-20-2008 05:04 AM - edited 03-13-2019 05:40 PM
Hi Guys,
What is the proper use of the sequence attribute in an axl request?
I've made all my requests work just using 1234.
But should I be doing something else with it?
Cheers,
Tim
09-21-2008 04:43 PM
I used 1234 also!!
It always works. But what is the meaning of this attribute??
Tony
09-25-2008 12:42 AM
it will work if you use 42 or 3 or anything else. In my opinion (theoretical) could be used to send more than one request at one time. You would need the sequence to devide the response for each.
But sending more than one request doesn't work ...
Axel
09-25-2008 01:32 AM
Yep I have seen it will take almost anything.. so maybe it could be useful for our own logging / debugging I suppose.
I havent got my VM in front of me. Does the AXL response include the Seq we used in the request?
I'm not a developer, so I havent paid great attention to what I get back yet :) I just get the stuff I need, and move on!
Cheers,
Tim.
09-25-2008 02:23 AM
Just for kicks I changed the 1234 in my code to 1235 and if the response that comes back isn't an error, it contains the same sequence number. However, for me that's not particularly useful since I'm launching requests synchronously and my axl lib already dumps the request/response pair to the logs if I max out the logging level.
