09-20-2008 05:51 AM - edited 03-15-2019 01:26 PM
I would like to deport a basic analog phone, directly connected on the PABX, on a remote site. As you can see on the drawing attached, i've used two routers; MAIN with FXO connected on PABX and REMOTE with FXS on which the analog phone is connected).
The problem is that the Analog phone (in blue) doesn't ring out when i call it. However if i pick the phone, i am able to hear or make conversation clearly.
Below the config of DP and voice-port for each router:
MAIN:
voice-port 1/0/0
cptone FR
timeouts call-disconnect 3
connection plar 3089
dial-peer voice 1 voip
destination-pattern 3089
session target ipv4:10.52.31.122
dtmf-relay h245-signal
dial-peer voice 3 pots
destination-pattern 1111
port 1/0/0
forward-digits all
REMOTE:
voice-port 0/2/0
cptone FR
connection plar 1111
destination-pattern ....
session target ipv4:10.52.31.121
port 0/2/0
forward-digits all
Moreover, from the MAIN router if i perform the command "csim start 3089" the FXS remote phone rings.
I think it should be a signaling problem but i cannot find out the problem.
Do you have any suggest ?
Thanks in advance,
Adrien
09-21-2008 10:38 PM
Anyone for suggest ?
09-22-2008 12:25 AM
have you got an FXS port on the main router where you could connect the phone?
i take it the phone is ok when directly connected to the PABX
09-22-2008 10:42 PM
I've found where the problem was coming from ! Actually it was an hardware config problem. The problem was because jumpers on the FXO card didn't set properly. The jumpers were set for ground-start instead of loop-start. See below:
"On Certain FXO VICs include two jumper headers, W3 and W4, to set loop-start or ground-start mode. One jumper configures each FXO port. The default setting, which should be satisfactory in most installations, is loop start. In this setting, jumpers are placed over positions 2 and 3 of headers W3 and W4. Most modern central office equipment, such as DMS-100 and 5ESS switches, provides calling party control (CPC) and Ring on Seize on loop-start lines. CPC allows quicker disconnection, and Ring on Seize minimizes glare (collision of inbound and outbound calls on the same interface). If your central office does not provide these features on loop start, you may want to configure the FXO card for ground-start operation instead by moving the jumpers to positions 1 and 2. For proper operation, both jumpers must be configured identically. In most cases, jumper setting should have little or no effect on operation. "
